Ir para o conteúdo principal
The Claw Item Replacement
Alain Pierre
Alain Pierre e 2 outros colaboradores
Última atualização em February 11, 2024
5 - 10 minutos
Fácil
Pré-requisitos incompatíveis
After repeated use of the claw machine, eventually you will run out of toys or candy to grab. In order to complete this task you will need to remove the top cover of your claw machine. Follow this user friendly guide to assist you with this task.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. The Claw Item Replacement, Top Cover: passo 1, imagem 1 %32
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Item Replacement: passo 2, imagem 1 %32
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Item Replacement: passo 3, imagem 1 %32
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Item Replacement: passo 4, imagem 1 %32
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Item Replacement: passo 5, imagem 1 %32
    • Remove the top cover of The Claw machine.
  6. The Claw Item Replacement: passo 6, imagem 1 %32 The Claw Item Replacement: passo 6, imagem 2 %32
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Item Replacement: passo 7, imagem 1 %32
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Item Replacement, Overfill: passo 8, imagem 1 %32
    • After emptying out contents have The Claw machine facing you
  9. The Claw Item Replacement: passo 9, imagem 1 %32
    • View the Claw machine from the top
  10. The Claw Item Replacement: passo 10, imagem 1 %32
    • Place thumb on grip section and pull away from the Claw machine.
  11. The Claw Item Replacement: passo 11, imagem 1 %32
    • Place items in the Claw machine.
Conclusão
Alain Pierre
Membro desde: 03/22/16
1.188 Reputação
Autoria de 9 guias
Equipe
UMass Dartmouth, Team 4-8, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,454
