Ir para o conteúdo principal
The Claw Case Replacement
Alain Pierre
Alain Pierre e 2 outros colaboradores
Última atualização em February 11, 2024
20 - 40 minutos
Moderada
If the clear plastic case on your claw device is broken or damaged, it can easily be replaced. This required the opening of the top cover of your claw device in order to access the clear plastic panels. Using this easy to follow replacement guide will make case replacement an easy task.
O que você precisa
Peças
Ferramentas
  1. The Claw Case Replacement, Top Cover: passo 1, imagem 1 %32
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Case Replacement: passo 2, imagem 1 %32
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Case Replacement: passo 3, imagem 1 %32
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Case Replacement: passo 4, imagem 1 %32
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Case Replacement: passo 5, imagem 1 %32
    • Remove the top cover of The Claw machine.
  6. The Claw Case Replacement: passo 6, imagem 1 %32 The Claw Case Replacement: passo 6, imagem 2 %32
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Case Replacement: passo 7, imagem 1 %32
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Case Replacement, Case: passo 8, imagem 1 %32
    • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
  9. The Claw Case Replacement: passo 9, imagem 1 %32
    • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
  10. The Claw Case Replacement: passo 10, imagem 1 %32
    • Gently remove the broken clear plastic case.
    • Remember how the case sat into the frame so that you can seat the new case in the same way.
Conclusão
Alain Pierre
Membro desde: 03/22/16
1.188 Reputação
Autoria de 9 guias
Equipe
UMass Dartmouth, Team 4-8, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
Membros da 3
Autoria de 18 guias
Um comentário
where can i get the clear plastic panels
cristian2002 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,565
