The Claw "Claw" Replacement
Introdução
Vá para o passo 1If you are experiencing trouble with the claw or it does not seem to be opening or closing properly, it is possible that the claw itself is broken or damaged. This requires the user to open the claw device in order to access the mechanical claw. Follow this easy guide in order to properly and easily replace your claw.
O que você precisa
Place The Claw machine in the up-right position with the control knobs facing you.
6 comentários
Where do I buy a new grabber thing
The 1st joystick that moves the claw forward and back doesn’t work.
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
My chain fell off and I dont know how to fix
