Ir para o conteúdo principal
TCA PRC 152A Disassembly
Tomazo_88
Tomazo_88 e um outro colaborador
Última atualização em April 2, 2021
25 - 45 minutos
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
This tutorial will explain how to completely disassemble the TCA PRC 152A radio and accessories.
Disclaimer : Disconnect all peripherals before disassembling.
O que você precisa
Ferramentas
Exibir mais…
  1. TCA PRC 152A Disassembly, Prepare the radio for dissasembly: passo 1, imagem 1 %32
    • Remove antenna and battery before dissasembly
    • Prepare the tools before starting We'll start with the radio and then the accessories...
  2. TCA PRC 152A Disassembly, Removing the backpannel: passo 2, imagem 1 %32 TCA PRC 152A Disassembly, Removing the backpannel: passo 2, imagem 2 %32 TCA PRC 152A Disassembly, Removing the backpannel: passo 2, imagem 3 %32
    • Remove 4 screws on the backpannel
    • Phillips PH3
    • The small retention piece is held by the screw. Be careful not to lose the spring
  3. TCA PRC 152A Disassembly, Removing the backpanel: passo 3, imagem 1 %32 TCA PRC 152A Disassembly, Removing the backpanel: passo 3, imagem 2 %32
    • Carefully open the rear panel with the opener's plastic tool.
    • You can see the connection map of the different terminals.
    • GPS option (Does not work)
    • PTT and config button socket
    • U283 6PIN connector
    • ON/OFF/Volume knob
    • Side connector (Does not work)
  4. TCA PRC 152A Disassembly, Removing frontpannel: passo 4, imagem 1 %32 TCA PRC 152A Disassembly, Removing frontpannel: passo 4, imagem 2 %32 TCA PRC 152A Disassembly, Removing frontpannel: passo 4, imagem 3 %32
    • Carefully open the front panel with the opener's plastic tool.
    • Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
    • Speaker FCE 16Ohm 1Watt.
    • Beware of silicone for the sealing of the elements.
  5. TCA PRC 152A Disassembly, Frontpannel microphone removal: passo 5, imagem 1 %32 TCA PRC 152A Disassembly, Frontpannel microphone removal: passo 5, imagem 2 %32 TCA PRC 152A Disassembly, Frontpannel microphone removal: passo 5, imagem 3 %32
    • Remove 1 screw
    • Phillips PH1
    • Carefully remove withe the plastic tool
  6. TCA PRC 152A Disassembly, Display and keyboard front card: passo 6, imagem 1 %32 TCA PRC 152A Disassembly, Display and keyboard front card: passo 6, imagem 2 %32 TCA PRC 152A Disassembly, Display and keyboard front card: passo 6, imagem 3 %32
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the flat connector
    • Use caution when you remove the flat connector
  7. TCA PRC 152A Disassembly, Display and keyboard front card: passo 7, imagem 1 %32 TCA PRC 152A Disassembly, Display and keyboard front card: passo 7, imagem 2 %32
    • Place the electronics elements on ESD bags
  8. TCA PRC 152A Disassembly, Peripheral back card: passo 8, imagem 1 %32 TCA PRC 152A Disassembly, Peripheral back card: passo 8, imagem 2 %32 TCA PRC 152A Disassembly, Peripheral back card: passo 8, imagem 3 %32
    • Disconnect 2 JSP connectors and 2 flat connector
    • Remove 4 screws
    • Phillips PH2
    • Carefully disconect the connectors and the board
  9. TCA PRC 152A Disassembly, Mainboard removal: passo 9, imagem 1 %32 TCA PRC 152A Disassembly, Mainboard removal: passo 9, imagem 2 %32 TCA PRC 152A Disassembly, Mainboard removal: passo 9, imagem 3 %32
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the antenna connector
    • Carefully removing the mainboard
    • Thermal paste between the card and the body
  10. TCA PRC 152A Disassembly, Side connectors removal: passo 10, imagem 1 %32 TCA PRC 152A Disassembly, Side connectors removal: passo 10, imagem 2 %32
    • Remove 2 screws
    • Phillips PH1
    • Carefully removing the connector
  11. TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 11, imagem 1 %32 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 11, imagem 2 %32 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 11, imagem 3 %32
    • Remove 2 screws
    • Phillips PH3
    • Remove the topcover, take care about short circuit
  12. TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 12, imagem 1 %32 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 12, imagem 2 %32 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 12, imagem 3 %32
    • Remove battery stick (18650 Panasonic)
    • Remove 2 screws
    • Phillips PH3
    • Take off the inner white retainer
Linha de Chegada
Uma outra pessoa concluiu este guia.
Tomazo_88
Membro desde: 06/09/20
379 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 73
Ao todo: 3,689
