Ir para o conteúdo principal
Soontrans Ergonomic Gaming Chair Wheel Replacement
Sharmarke Salah-Mohamed
Sharmarke Salah-Mohamed e um outro colaborador
Última atualização em May 4, 2022
15 minutos
Fácil
Fotos de ação
Precisa de melhores imagens
Replacing the Soontrans Ergonomic Gaming Chair wheels is a fairly straightforward operation. The instructions below will direct you in a way where minimal to no error may occur during the procedure. Once the chair has been worn out due to years of aggressive movement many issues tend to occur, but the main issue that can be solved by yourself, which is replacing the wheels. With these instructions, I guarantee you'll be back to working or gaming in no time!
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Soontrans Ergonomic Gaming Chair Wheel Replacement, Wheels: passo 1, imagem 1 %32
    • Flip the chair on its backside so the seat is facing upwards.
    • Use the 4 mm Hex key to remove the 4 hexagonal sockets attaching the hydraulic press to the seat.
  2. Soontrans Ergonomic Gaming Chair Wheel Replacement: passo 2, imagem 1 %32
    • Detach the hydraulic press from the chair.
  3. Soontrans Ergonomic Gaming Chair Wheel Replacement: passo 3, imagem 1 %32
    • Remove the wheels from the legs.
  4. Soontrans Ergonomic Gaming Chair Wheel Replacement: passo 4, imagem 1 %32 Soontrans Ergonomic Gaming Chair Wheel Replacement: passo 4, imagem 2 %32
    • Replace your new wheels by pushing them back into place.
  5. Soontrans Ergonomic Gaming Chair Wheel Replacement: passo 5, imagem 1 %32
    • Use the 4 mm Hex key to reattach the legs to the hydraulic press and screw the component back to the seat with the 4 hexagonal sockets.
  6. Soontrans Ergonomic Gaming Chair Wheel Replacement: passo 6, imagem 1 %32
    • Now enjoy!!!!
Conclusão
Congratulations you made it!
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 680
