Ir para o conteúdo principal
Sony Xperia Z1 Compact Screen Replacement
jaanparker
jaanparker e um outro colaborador
Última atualização em December 8, 2016
25 minutos
Fácil
Guia colaborativo
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Sony Xperia Z1 Compact Screen Replacement, Apply heat: passo 1, imagem 1 %32
    • Apply heat to the edges.
  2. Sony Xperia Z1 Compact Screen Replacement, Start prying: passo 2, imagem 1 %32
    • When the glue is warm slowly start prying from the top corner.
  3. Sony Xperia Z1 Compact Screen Replacement, Add more heat if necessary: passo 3, imagem 1 %32
    • If the glue is cooled down heat more. Don't force it.
  4. Sony Xperia Z1 Compact Screen Replacement, Cable: passo 4, imagem 1 %32
    • Remove the data cable from the phones body.
  5. Sony Xperia Z1 Compact Screen Replacement, Testing new screen: passo 5, imagem 1 %32
    • Test if the new screen works properly.
  6. Sony Xperia Z1 Compact Screen Replacement, The tape: passo 6, imagem 1 %32
    • If the screen works, remove the new screen and add the double sided tape
  7. Sony Xperia Z1 Compact Screen Replacement, Connecting new screen: passo 7, imagem 1 %32
    • Connect the new screen to the phone.
  8. Sony Xperia Z1 Compact Screen Replacement, Apply force: passo 8, imagem 1 %32
    • Now push town not to tight not to softly to the screen.
    • And that's it. You finished the screen replacement.
Conclusão
30 outras pessoas executaram este guia.
jaanparker
Membro desde: 01/21/16
952 Reputação
Autoria de 1 guia
5Comentários do guia
There is a very good Youtube video of this. I think these are screenshots from it.
Andrew - Responder
Good video! Help me too! Thanks
Clodoaldo Castro - Responder
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
sinistre - Responder
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
Marcus Roach - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 17,827
