Ir para o conteúdo principal
Sony Xperia XA Loudspeaker Replacement
Stephen Rock
Stephen Rock e 3 outros colaboradores
Última atualização em May 29, 2018
15 minutos
Moderado
Introdução
Ir para o passo 1
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Xperia XA Loudspeaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Loudspeaker Replacement: passo 2, imagem 1 %32
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Loudspeaker Replacement: passo 3, imagem 1 %32 Sony Xperia XA Loudspeaker Replacement: passo 3, imagem 2 %32 Sony Xperia XA Loudspeaker Replacement: passo 3, imagem 3 %32
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Loudspeaker Replacement: passo 4, imagem 1 %32 Sony Xperia XA Loudspeaker Replacement: passo 4, imagem 2 %32 Sony Xperia XA Loudspeaker Replacement: passo 4, imagem 3 %32
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Loudspeaker Replacement: passo 5, imagem 1 %32
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Loudspeaker Replacement: passo 6, imagem 1 %32
    • Peel back the RAF antenna.
  7. Sony Xperia XA Loudspeaker Replacement, Loudspeaker: passo 7, imagem 1 %32 Sony Xperia XA Loudspeaker Replacement, Loudspeaker: passo 7, imagem 2 %32
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  8. Sony Xperia XA Loudspeaker Replacement: passo 8, imagem 1 %32 Sony Xperia XA Loudspeaker Replacement: passo 8, imagem 2 %32
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  9. Sony Xperia XA Loudspeaker Replacement: passo 9, imagem 1 %32
    • Pry the loudspeaker up with the spudger.
  10. Sony Xperia XA Loudspeaker Replacement: passo 10, imagem 1 %32
    • Remove the loudspeaker with your hands.
Conclusão
Stephen Rock
Membro desde: 04/18/18
230 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G2, Livingston Spring 2018 Membro de Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Membros
Autoria de 8 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 528
