Ir para o conteúdo principal
Sony PlayStation 3D Display Side Speakers Replacement
O que você precisa
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: passo 1, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: passo 2, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 2, imagem 2 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 2, imagem 3 %32
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: passo 3, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 3, imagem 2 %32
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: passo 4, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 4, imagem 2 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 4, imagem 3 %32
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: passo 5, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: passo 5, imagem 2 %32 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: passo 5, imagem 3 %32
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: passo 6, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 6, imagem 2 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 6, imagem 3 %32
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: passo 7, imagem 1 %32 Sony PlayStation 3D Display Side Speakers Replacement: passo 7, imagem 2 %32
    • Remove the speaker by depressing the white tab on the speaker wire connector.
Conclusão
3 outras pessoas executaram este guia.
viharim
Membro desde: 10/22/15
200 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-16, Maness Fall 2015 Membro de Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Membros
Autoria de 8 guias
1Comentário do guia
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 2,899
