Ir para o conteúdo principal
Sony ICF-CS15iP Disassembly
Adrian Lopez
Adrian Lopez e um outro colaborador
Última atualização em January 12, 2023
40 minutos - 3 horas
Moderado
Ferramentas incorretas
Acidente de Marcação
Guia colaborativo
Introdução
Ir para o passo 1
This is a complete tear down of the Sony ICF-CS15iP
Documento em destaque
  1. Sony ICF-CS15iP Disassembly, Remove all 18 screws from the device’s outer shell.: passo 1, imagem 1 %32 Sony ICF-CS15iP Disassembly, Remove all 18 screws from the device’s outer shell.: passo 1, imagem 2 %32
    • All of these damned screws are approx. a PH1 size.
  2. Sony ICF-CS15iP Disassembly, Remove back and base covers.: passo 2, imagem 1 %32 Sony ICF-CS15iP Disassembly, Remove back and base covers.: passo 2, imagem 2 %32 Sony ICF-CS15iP Disassembly, Remove back and base covers.: passo 2, imagem 3 %32
    • Pull on the back to ease it off, and there will be some wires that will need to be disconnected. (Green circled wire not necessary to remove but recommended)
  3. Sony ICF-CS15iP Disassembly, Remove power and antenna board.: passo 3, imagem 1 %32
    • Unfasten the 4 screws holding in the board.
  4. Sony ICF-CS15iP Disassembly, Remove display.: passo 4, imagem 1 %32 Sony ICF-CS15iP Disassembly, Remove display.: passo 4, imagem 2 %32
    • Remove the following screws:
  5. Sony ICF-CS15iP Disassembly, Remove dock: passo 5, imagem 1 %32
    • Remove the following screws and be careful with the dock connector, as it has springs that can fly to oblivion.
  6. Sony ICF-CS15iP Disassembly, Remove speaker assembly.: passo 6, imagem 1 %32
  7. Sony ICF-CS15iP Disassembly, Take a break (optional): passo 7, imagem 1 %32
    • I chose to eat pretzels, you can have a 10 course meal prepared by Gordon Ramsay
  8. Sony ICF-CS15iP Disassembly, Remove speakers.: passo 8, imagem 1 %32
    • These are some good 4 ohm 5 watt speakers.
  9. Sony ICF-CS15iP Disassembly, Remove top buttons.: passo 9, imagem 1 %32
    • My specific board has some damage from the previous owner, and I only made it worse lol.
  10. Sony ICF-CS15iP Disassembly, Remove rear buttons.: passo 10, imagem 1 %32
    • This is definitely all the screws that need to be unfastened.
    • I used a PH1 and PH0 screwdriver.
Conclusão
Uma outra pessoa concluiu este guia.
Documentos anexados
Adrian Lopez
Membro desde: 01/14/21
527 Reputação
Autoria de 3 guias
1Comentário do guia
Buen día y muchas gracias por tomarse el tiempo de documentar el proceso de desarmar un CS15iPN. Tengo una pregunta por favor: ¿Cómo pudo desconectar los ribbons (que se observan en la foto del paso 4) de sus conectores en la tarjeta? Yo desarmé mi equipo y no me atreví a desconectar los ribbons porque me parecía que estaban "soldados" permanentemente en los conectores.
Luis - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 44
Ao todo: 544
