Introdução
Occasionally the LCD screen or the Back light on the camera will be cracked or simply stop working. This page outlines how to disassemble the camera in order to install replacement parts for any broken pieces.
Ferramentas
Peças
Nenhum componente especificado.
Locate the battery pack which can be found on the back side of the camera below the viewfinder.
Push in the small button on the bottom of the camera, marked with the red circle, then slide the entire switch forward, marked with the yellow rectangle.
Remove the (6) 4.5mm screws from the bottom of the Sony Handycam that are marked with small circles.
Remove the copper strip from the housing that connects the outer casing to the entire of the camera.
Remove (4) 2.9mm screws from the L-shaped circuit board. They are marked with red circles in the slide.
Remove the (3) wire strips connected to the camera so you can pull off the L-shaped circuit board.
Remove the single wire strip that is connected to the bottom of the circuit board.
Uma outra pessoa concluiu este guia.
