Ir para o conteúdo principal
Sony DCR-DVD 108 LCD Screen Replacement
Elijah DeWolf
Elijah DeWolf e 3 outros colaboradores
Última atualização em May 7, 2024
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
The LCD screen is the side screen on your camera that flips open. It is unfortunately easily damaged permanently; here is a guide to at least check basic electronic connections.
O que você precisa
Ferramentas
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
  2. Sony DCR-DVD 108 LCD Screen Replacement: passo 2, imagem 1 %32
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
  3. Sony DCR-DVD 108 LCD Screen Replacement: passo 3, imagem 1 %32
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
  4. Sony DCR-DVD 108 LCD Screen Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
Conclusão
Elijah DeWolf
Membro desde: 02/09/16
604 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 7-6, Cheng Spring 2016 Membro de USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 22
Ao todo: 918
