Ir para o conteúdo principal
Sony Cybershot DSC-W80 LCD Screen Replacement
Alfred Bee
Alfred Bee e 2 outros colaboradores
Última atualização em February 7, 2021
10 minutos
Moderado
Melhor Introdução
O que você precisa
Ferramentas
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Sony Cybershot DSC-W80 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Sony Cybershot DSC-W80 LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 LCD Screen Replacement: passo 2, imagem 1 %32
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: passo 3, imagem 1 %32 Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: passo 3, imagem 2 %32 Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: passo 3, imagem 3 %32
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 LCD Screen Replacement: passo 5, imagem 1 %32 Sony Cybershot DSC-W80 LCD Screen Replacement: passo 5, imagem 2 %32
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: passo 6, imagem 1 %32 Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: passo 6, imagem 2 %32 Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: passo 6, imagem 3 %32
    • Lift the power button board up off of the daughterboard.
  7. Sony Cybershot DSC-W80 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  8. Sony Cybershot DSC-W80 LCD Screen Replacement: passo 8, imagem 1 %32 Sony Cybershot DSC-W80 LCD Screen Replacement: passo 8, imagem 2 %32
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 869
