Ir para o conteúdo principal
Sony Cyber-shot DSC-WX80 LCD Screen Replacement
Benjamin Anderson
Benjamin Anderson e 5 outros colaboradores
Última atualização em January 10, 2025
25 - 45 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
Make sure you have the necessary tools in order to complete the LCD screen replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Begin by removing all six 40mm by 10mm black screws holding the outer frame together with the Phillips #00 screwdriver.
  2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 2, imagem 3 %32
    • Remove the free-moving flap near the battery port and store in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 3, imagem 3 %32
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
    There’s another thin frágil peace that came off but idk where from? I need some help. It’s small and has metal on it.
    Brayan - Responder
  4. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon.
    • Your LCD screen is now removed and you can replace it!
    New display purchase old display was damaged
    kuldeepsingh.r92 - Responder
    And body was cracked my sister sons throw my camera some parts damaged I need help
Conclusão
4 outras pessoas executaram este guia.
2Comentários do guia
Would the wheel be included with the LCD? The wheel on my camera is broken, and I would like to fix/replace it, so should I just order a new LCD screen?
Caleb V. - Responder
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
Jose Luis Martínez - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 1,886
