Sony Cyber-shot DSC-WX80 LCD Screen Replacement
Introdução
Ir para o passo 1Make sure you have the necessary tools in order to complete the LCD screen replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
O que você precisa
Peças
Ferramentas
Exibir mais…
Begin by removing all six 40mm by 10mm black screws holding the outer frame together with the Phillips #00 screwdriver.
Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial.
Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side.
Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
Ferramenta utilizada neste passo:Tweezers$4.99
Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device.
Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon.
Your LCD screen is now removed and you can replace it!
New display purchase old display was damaged
And body was cracked my sister sons throw my camera some parts damaged I need help
4 outras pessoas executaram este guia.
2Comentários do guia
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
