Ir para o conteúdo principal
Sony Cyber-shot DSC-WX100 LCD Screen Replacement
Peter Prins
Peter Prins e 2 outros colaboradores
Última atualização em June 22, 2015
20 minutos
Moderado
Introdução
Ir para o passo 1
The purpose of this guide is to replace the LCD screen. This guide will provide the necessary information to disassemble the camera, replace the screen, and to properly reassemble the components involved.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 2, imagem 1 %32
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: passo 3, imagem 3 %32
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so the plate is high enough so that the marked bump is not holding it in place.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help please watch the video.
  6. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 7, imagem 2 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 7, imagem 3 %32
    • Remove this screw (1mm) with a Phillips #000 Screwdriver.
    • Gently lift the LCD from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: passo 8, imagem 3 %32
    • Use the plastic opening tool to pry the black bar upwards.
    • Pull the LCD screen from out of the slot.
Conclusão
Uma outra pessoa concluiu este guia.
Peter Prins
Membro desde: 03/19/15
262 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
be careful with capacitor !!! i touched it 5-10 minutes after battery was removed and felt electricity in my chest, ears… be careful :D
k.bilius - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 1,432
