Ir para o conteúdo principal
Sony Cyber-shot DSC-WX100 Image Sensor Replacement
Matthew
Matthew e 2 outros colaboradores
Última atualização em June 22, 2015
25 minutos
Moderado
Introdução
Ir para o passo 1
This guide will allow the reader to how to disassemble the DSC-WX100 and get to its image sensor.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Battery: passo 1, imagem 1 %32
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 2, imagem 1 %32
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Outer Casing: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Outer Casing: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement, Outer Casing: passo 3, imagem 3 %32
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so that the plate is uninhibited by the indicated bump.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help with this step, refer to the video.
  6. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 7, imagem 2 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 7, imagem 3 %32
    • Remove this screw (1mm) with the Phillips #000 Screwdriver.
    • Gently lift the LCD screen component from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 8, imagem 3 %32
    • Peel back the copper sheet.
    • Unscrew the three marked screws (2mm) using a Phillips #000 Screwdriver.
    • Remove the panel attached by said screws.
  8. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 9, imagem 1 %32
    • Peel back both the copper sheet and the black tape underneath the panel to expose the connection port.
  9. Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 10, imagem 2 %32 Sony Cyber-shot DSC-WX100 Image Sensor Replacement: passo 10, imagem 3 %32
    • Use a plastic opening tool to pry the black bar upwards.
    • Pull the image sensor out after the black tab is released.
Conclusão
Matthew
Membro desde: 03/18/15
583 Reputação
Autoria de 4 guias
Equipe
1Comentário do guia
thanks a lot very helpfull.
could you precise( in remounting phase) that it is necessary to take care of the position of the back slider (photo/pano/video) before screwing, it will avoid to dismount again…….
regards
Olivier TRIFT - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 1,003
