Ir para o conteúdo principal
Sony Cyber-shot DSC-W730 LCD Screen Replacement
Jeremy Petchonka
Jeremy Petchonka e 4 outros colaboradores
Última atualização em 7 de mai de 2024
15 minutos
Fácil
Introdução
Ir para o passo 1
This will help solve a lot of black screen problems, as you should be able to see if the ribbon is connected or the LCD screen is damaged. Be careful with the ribbons.
O que você precisa
Ferramentas
  • Phillips #000 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Exibir mais…
  1. Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement, Removing the Case: passo 1, imagem 3 %32
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 2, imagem 3 %32
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 3, imagem 2 %32
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 5, imagem 3 %32
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Control Board: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W730 LCD Screen Replacement: passo 8, imagem 2 %32
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Jeremy Petchonka
Membro desde: 01/20/15
279 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-4, Blackwell Winter 2015 Membro de USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 Membros
Autoria de 12 guias
2Comentários do guia
Excellent tutorial. It helped me a lot. I ve just replaced my LCD with success.
Thank you
joao - Responder
I can record with the camera but I can't see the image while taking photos. Any suggestions?
Robin_o - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 1,779
