Ir para o conteúdo principal
Sony Cyber-shot DSC-W5 LCD Screen Replacement
Thomas
Thomas e 8 outros colaboradores
Última atualização em December 19, 2020
Nenhuma estimativa
Moderado
Ferramentas incorretas
Introdução
Ir para o passo 1
This guide will show you how to access the LCD screen in order to repair or replace the screen.
O que você precisa
Ferramentas
A iFixit ganha comissão quando você compra por estes links.
  1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 3, imagem 2 %32
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: passo 4, imagem 2 %32
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 5, imagem 1 %32
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 6, imagem 2 %32
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 7, imagem 2 %32 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 7, imagem 3 %32
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
Conclusão
4 outras pessoas executaram este guia.
Thomas
Membro desde: 04/14/10
142 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 15-50, Garner Spring 2010 Membro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Ao todo: 11,619
