Ir para o conteúdo principal
Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Front Panel: passo 1, imagem 1 %32 Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Front Panel: passo 1, imagem 2 %32
    • Remove all seven black 4 mm Philips #00 screws holding the front panel into place. Two on each of the sides of the camera and three on the bottom.
  2. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement: passo 2, imagem 3 %32
    • Gently lift the front panel up off the back of the camera prying up around the edges using a plastic opening tool or spudger if necessary.
  3. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Inner Screw: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Inner Screw: passo 3, imagem 2 %32
    • Remove the one sliver 4mm Philips #00 screw that is holding the receptacle in place near the bottom of the camera.
    • There is one other screw just like this one on the top of the camera near the capture button. That’s not the one you want to remove here
  4. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Tripod Receptacle: passo 4, imagem 1 %32 Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Tripod Receptacle: passo 4, imagem 2 %32
    • Remove the tripod receptacle by simply lifting it out with your hands or with tweezers if necessary.
Conclusão
Chelsea Vitone
Membro desde: 01/21/15
213 Reputação
Autoria de 2 guias
Equipe
UWT Liner: Group 4 Membro de UWT Liner: Group 4
Community
Membros da 6
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 333
