Ir para o conteúdo principal
Sony Cyber-shot DSC-T500 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: passo 1, imagem 1 %32 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: passo 1, imagem 2 %32
    • There are 4 screws total holding the outer shell of the camera. One on each corner. To reach the bottom two, you have to slide the camera cover up. Vise versa for the top two.
    • Make sure to remove the battery before taking the camera apart.
  2. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: passo 2, imagem 1 %32 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: passo 2, imagem 2 %32
    • Separate the front and back housings carefully.
    • Be careful not to pry it apart as they are connected together by the LCD ribbon cables.
    • Once you have separated the two housings unplug the LCD ribbon cables.
    • There should be three. One big one and two small ones
    • Remove the LCD screen from the housing.
    • You'll have to carefully lift the internal components of the camera in order to remove the LCD screen.
Conclusão
Chelsea Vitone
Membro desde: 01/21/15
213 Reputação
Autoria de 2 guias
Equipe
UWT Liner: Group 4 Membro de UWT Liner: Group 4
Community
Membros da 6
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 394
