Ir para o conteúdo principal
Sony Cyber-shot DSC-T1 LCD Replacement
iDeleted
iDeleted e 8 outros colaboradores
Última atualização em December 8, 2020
2 minutos
Moderado
Guia colaborativo
Fotos de ação
Polícia gramatical
Precisa de melhores imagens
Introdução
Ir para o passo 1
Taking out the LCD is one of the more difficult things to do on your Cyber-shot. Because the LCD is located at the back of the camera you will have to take apart the entire camera just to reach it.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Sony Cyber-shot DSC-T1 LCD Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 LCD Replacement: passo 2, imagem 1 %32
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 2 %32 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, imagem 3 %32
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 LCD Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement: passo 4, imagem 2 %32
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: passo 5, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: passo 5, imagem 2 %32
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 LCD Replacement: passo 6, imagem 1 %32
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: passo 7, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  8. Sony Cyber-shot DSC-T1 LCD Replacement: passo 8, imagem 1 %32
    • Remove the ribbon cables from these two ZIF connectors.
  9. Sony Cyber-shot DSC-T1 LCD Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement: passo 9, imagem 2 %32
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  10. Sony Cyber-shot DSC-T1 LCD Replacement, LCD: passo 10, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement, LCD: passo 10, imagem 2 %32
    • Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
  11. Sony Cyber-shot DSC-T1 LCD Replacement: passo 11, imagem 1 %32 Sony Cyber-shot DSC-T1 LCD Replacement: passo 11, imagem 2 %32
    • Remove the back frame from the LCD assembly.
    • Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
  12. Sony Cyber-shot DSC-T1 LCD Replacement: passo 12, imagem 1 %32
    • Pull the tape off that holds the LCD to the assembly.
Conclusão
iDeleted
Membro desde: 07/07/10
2.101 Reputação
Autoria de 39 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 43
Ao todo: 4,645
