Ir para o conteúdo principal
Sony Cyber-shot DSC-HX300 Motherboard Replacement
Elizabeth Surface
Elizabeth Surface e 6 outros colaboradores
Última atualização em January 10, 2025
30 minutos - 1 hora
Difícil
If the Sony Cyber-shot DSC-HX300 is failing to power, while it has a full battery and the LCD screen works, then it is possible that the motherboard has gone out and needs to be replaced.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 2, imagem 1 %32
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 3, imagem 1 %32
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 8, imagem 3 %32
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-HX300 Motherboard Replacement: passo 9, imagem 2 %32
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
Conclusão
Elizabeth Surface
Membro desde: 08/26/15
1.465 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 4-6, Meier Fall 2015 Membro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Membros da 4
Autoria de 18 guias
3 comentários
During my vacation two capicators on the motherboard failed and 'exploded'.
I've ordered the motherboard and replaced it exactly as described here. Thanks for the explanation!
But since I've replaced it, I have autofocus problems, the camera isn't capable to focus, especially in wide zoom.
Is this something that needs to be calibrated or something?
Erik Mourik - Responder
Where can you order a motherboard?
Astrid - Responder
That ist what i need to know too. Where can i order a Motherboard?
Jürgen Frömmert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 2,879
