Ir para o conteúdo principal
Sony Cyber-shot DSC-HX300 Battery Replacement
Elizabeth Surface
Elizabeth Surface e 7 outros colaboradores
Última atualização em January 10, 2025
20 segundos - 1 minuto
Muito fácil
If the battery is not holding charge like it used to, then it may be time to replace it.
  1. Sony Cyber-shot DSC-HX300 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 Battery Replacement: passo 2, imagem 1 %32
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 Battery Replacement: passo 3, imagem 1 %32
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 Battery Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-HX300 Battery Replacement: passo 4, imagem 2 %32
    • Remove the battery.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure to not skip a step as it will not work correctly if there was an error in reassembling the camera.
Uma outra pessoa concluiu este guia.
Elizabeth Surface
Membro desde: 08/26/15
1.465 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 4-6, Meier Fall 2015 Membro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Membros da 4
Autoria de 18 guias
Um comentário
How to replace the internal battery?
Neptue - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 3,196
