Ir para o conteúdo principal
Sony Cyber-shot DSC-H200 LCD Screen Replacement
Elizabeth Morrison
Elizabeth Morrison e 6 outros colaboradores
Última atualização em May 7, 2024
15 minutos
Moderado
Despedaçar
Introdução
Ir para o passo 1
In order to change a broken screen, you need to get into the body of the camera. We will show you how to not only take apart your camera but also how to replace a broken screen. Properly following the steps included will ensure a safe and easy LCD Screen replacement.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 2, imagem 1 %32
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 3, imagem 1 %32
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 5, imagem 1 %32
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 6, imagem 1 %32
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 7, imagem 2 %32
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 9, imagem 2 %32 Sony Cyber-shot DSC-H200 LCD Screen Replacement: passo 9, imagem 3 %32
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
Conclusão
1Comentário do guia
Where can you purchase a new replacement monitor?
Butch Sullivan - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 2,738
