Sony Cyber-Shot DSC-W170 LCD Panel Assembly Replacement
Introdução
Ir para o passo 1This guide will help you to replace the LCD panel unit on the Sony Cyber Shot DSC-W170.
If the screen protector or menu buttons are not working properly, the solution is to replace the LCD panel unit. The following is a step-by-step guide to removing the LCD panel unit and replacing it with a working one. Be careful when removing shattered glass displays and be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
O que você precisa
