Sony Alpha a7s II LCD Replacement
Introdução
Ir para o passo 1The LCD screen can be pulled out to a couple of different angles. However, be careful when angling it because it does have restrictions. Doing so past those restrictions will break the LCD bracket holding it in place.
O que você precisa
Ferramentas
Lift the LCD screen to unscrew the 2 screws on its underside.
What is the screw size on these on the screen because I lost some and I am trying to replace it?
10 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all4Comentários do guia
And the how do you change the LCD screen please ? How to remove it ?
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
What size screws!?
