Ir para o conteúdo principal
Sony Alpha 6000 Shutter Button Replacement
Fernando Sierra
Fernando Sierra e 6 outros colaboradores
Última atualização em 7 de mai de 2024
20 minutos
Difícil
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
Introdução
Ir para o passo 1
If there are problems with the camera recognizing the press of the shutter button, this guide will show you step-by-step instructions on how to remove the button in order to replace it.
O que você precisa
Ferramentas
Exibir mais…
  1. Sony Alpha 6000 Shutter Button Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the camera is turned off by turning the switch to OFF.
  2. Sony Alpha 6000 Shutter Button Replacement: passo 2, imagem 1 %32
    • Flip the camera around to access the battery compartment.
    • Slide the battery compartment lock to the left to unlock it.
  3. Sony Alpha 6000 Shutter Button Replacement: passo 3, imagem 1 %32
    • Locate the blue latch that holds the battery in.
  4. Sony Alpha 6000 Shutter Button Replacement: passo 4, imagem 1 %32
    • Push the latch back to release battery.
  5. Sony Alpha 6000 Shutter Button Replacement: passo 5, imagem 1 %32
    • The battery can now be taken out of its compartment.
  6. Sony Alpha 6000 Shutter Button Replacement, Back Cover: passo 6, imagem 1 %32
    • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
    This step is not necessary.
    Jocelito - Responder
    I think it is necessary…
    Torsten S. - Responder
  7. Sony Alpha 6000 Shutter Button Replacement: passo 7, imagem 1 %32
    • Turn the camera sideways.
    • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
    • Unscrew using the J00 head screw.
  8. Sony Alpha 6000 Shutter Button Replacement: passo 8, imagem 1 %32
    • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
    There are one more screw near the blue latch.
    Jocelito is right.
  9. Sony Alpha 6000 Shutter Button Replacement: passo 9, imagem 1 %32
    • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
    • Locate them and unscrew them.
    There's also a screw under the dial just to the right of the viewfinder. You have to pull off a sticker in the middle of it to access. I also removed the top part of the camera in order to easier remove the back. It may not be necessary to do this.
    Margar - Responder
    That is correct, I think it is necessary to do so, at least it is much easier that way.
  10. Sony Alpha 6000 Shutter Button Replacement: passo 10, imagem 1 %32 Sony Alpha 6000 Shutter Button Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
    • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
    Is not necessary remove the back cover to remove the top cover.
    But it is necessary to remove the back cover to change the Jog Wheel and that is what the instruction is for…
  11. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: passo 11, imagem 1 %32
    • Once the back cover is off, locate the flash of the camera and push it forward to open it
  12. Sony Alpha 6000 Shutter Button Replacement: passo 12, imagem 1 %32
    • Locate the two 3 mm screws within the flash and unscrew them
  13. Sony Alpha 6000 Shutter Button Replacement: passo 13, imagem 1 %32
    • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
  14. Sony Alpha 6000 Shutter Button Replacement: passo 14, imagem 1 %32 Sony Alpha 6000 Shutter Button Replacement: passo 14, imagem 2 %32
    • Hold the top of the camera away from the body.
    • Carefully turn it over to uncover the bottom of the shutter button.
  15. Sony Alpha 6000 Shutter Button Replacement: passo 15, imagem 1 %32
    • Locate the two screws holding the shutter button and unscrew them.
  16. Sony Alpha 6000 Shutter Button Replacement: passo 16, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
  17. Sony Alpha 6000 Shutter Button Replacement: passo 17, imagem 1 %32
    • Turn the top plastic piece back over.
    • Now you will be able to completely remove the camera's shutter button.
Conclusão
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Fernando Sierra
Membro desde: 09/30/16
376 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 4-5, Passmore Fall 2016 Membro de USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Membros
Autoria de 12 guias
4Comentários do guia
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Responder
Where can i buy a replacement button?
Simon Lundh - Responder
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster -
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 64
Últimos 30 dias: 186
Ao todo: 18,022
