Ir para o conteúdo principal
Shutting off the Water Supply to a Toilet
Ron Davis
Ron Davis e 2 outros colaboradores
Última atualização em October 15, 2024
30 segundos
Muito fácil
Use this guide to shut off the water supply to your toilet. This procedure is an important step for most toilet repairs.
  1. Shutting off the Water Supply to a Toilet, Shutting off the Water Supply to a Toilet: passo 1, imagem 1 %32 Shutting off the Water Supply to a Toilet, Shutting off the Water Supply to a Toilet: passo 1, imagem 2 %32
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
Linha de Chegada
Ron Davis
Membro desde: 02/17/15
32.036 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 48
Últimos 30 dias: 139
Duração total: 4,233
