Ir para o conteúdo principal
Shower Head Replacement
O que você precisa
  1. Shower Head Replacement, Shower Head: passo 1, imagem 1 %32
    • Use your hand to loosen the old shower head from the pipe. This should be fairly easy, as most shower heads have a textured grip on the joint.
    • Make sure the water is turned off to the shower.
  2. Shower Head Replacement: passo 2, imagem 1 %32
    • Once the shower head is loosened, remove it and set it aside.
  3. Shower Head Replacement: passo 3, imagem 1 %32
    • Remove the old plumbing tape from the threads of the pipe, and throw it away.
  4. Shower Head Replacement: passo 4, imagem 1 %32
    • Grab your roll of plumbing tape and wrap the tape approximately twice around the threads of the pipe.
    • Be sure to wrap the tape tightly to prevent leaks.
  5. Shower Head Replacement: passo 5, imagem 1 %32
    • Begin installing the new shower head by threading it onto the pipe.
  6. Shower Head Replacement: passo 6, imagem 1 %32
    • Use your hands to tighten the new shower head back onto the pipe, using a wrench if needed.
    • Make sure it is tightly connected!
  7. Shower Head Replacement: passo 7, imagem 1 %32
    • Turn on the water and enjoy your new shower head!
Conclusão
Uma outra pessoa concluiu este guia.
Aaron Bartfeld
Membro desde: 02/23/15
205 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-3, Green Winter 2015 Membro de Cal Poly, Team 12-3, Green Winter 2015
CPSU-GREEN-W15S12G3
4 Membros
Autoria de 7 guias
4Comentários do guia
Great post. Very informative and easy to follow! Beautiful hand model, absolutely superb! Is he single by any chance?
nprewitt - Responder Compartilhar
My shower isn’t broken I just keep looking at the incredible hand model! Wow! I would break my shower head if these hands would fix it
Abby - Responder Compartilhar
What a helpful guide . And Wow! I couldn't help but notice some phenomenal hand modeling. Those hands are going places that's for sure!
Ronaldo Villa - Responder Compartilhar
What does his feet look like? Haha.
Sounds like fake replies. 3 people saying the same thing on the same exact day. Gtfoh.
Kimmy (Kimmy Kimmy Bang Bang) - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 93
Ao todo: 3,882
