Shank Button Replacement
Introdução
Ir para o passo 1A shank button is any button with a loop (or shank) on the back. This type of button is very easy to replace and will extend the life of your garment!
O que você precisa
Ferramentas
Exibir mais…
Remove your loose button (if necessary).
If the button is already missing, remove any loose threads from your garment.
Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
Pull the thread until the knot rests on the fabric.
Insert your needle into the shank on the back of your button.
Pull the thread until the button rests on the fabric.
Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
