Ir para o conteúdo principal
Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement
James Thorne
James Thorne e 11 outros colaboradores
Última atualização em August 8, 2019
15 minutos
Moderada
Precisa de melhores imagens
Precisa de mais images
Ajustador de passo
Follow this guide to replace a faulty headphone jack in your Sandisk Sansa m230 Series MP3 Player.
O que você precisa
Ferramentas
Exibir mais…
  1. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement, Sandisk Sansa m230 Series mp3 player Teardown: passo 1, imagem 1 %32
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 2, imagem 1 %32
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 3, imagem 1 %32
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 4, imagem 1 %32
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 5, imagem 1 %32
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 6, imagem 1 %32
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement, Headphone Jack: passo 7, imagem 1 %32
    • Locate the headphone jack on the motherboard.
  8. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 8, imagem 1 %32
    • Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
    • The solder and soldering iron are very hot! Do not touch unless you are wearing appropriate protective gloves.
  9. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 9, imagem 1 %32 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 9, imagem 2 %32 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 9, imagem 3 %32
    • Use soldering iron to melt the existing solder at the three headphone jack connections.
  10. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 10, imagem 1 %32
    • Remove the faulty headphone jack from the motherboard.
  11. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 11, imagem 1 %32
    • Align the new headphone jack appropriately on the motherboard for soldering.
  12. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 12, imagem 1 %32 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 12, imagem 2 %32 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: passo 12, imagem 3 %32
    • Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack.
    • Allow the new solder to cool and harden before reassembling the MP3 player.
Conclusão
James Thorne
Membro desde: 11/05/13
665 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Membro de UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,192
