Ir para o conteúdo principal
Samsung Watch Active Battery Replacement
Jimi Aloba
Jimi Aloba e 2 outros colaboradores
Última atualização em August 6, 2024
Nenhuma estimativa
Fácil
Guia colaborativo
O que você precisa
Ferramentas
Exibir mais…
  1. Samsung Watch Active Battery Replacement, Tools: passo 1, imagem 1 %32
    • Assemble all your tools
  2. Samsung Watch Active Battery Replacement: passo 2, imagem 1 %32
    • Turn watch faced down to reveal the screws. Remove the straps by pulling on pin switches to release.
  3. Samsung Watch Active Battery Replacement: passo 3, imagem 1 %32 Samsung Watch Active Battery Replacement: passo 3, imagem 2 %32
    • remove the 4 screws
  4. Samsung Watch Active Battery Replacement: passo 4, imagem 1 %32
    • Use the tin metal pry tool to gently penetrate the back.
  5. Samsung Watch Active Battery Replacement: passo 5, imagem 1 %32
    • Use the metal pry tool as support for the opening blue pick
  6. Samsung Watch Active Battery Replacement: passo 6, imagem 1 %32
    • Gently Lift the back to reveal a connector, use a tweezer to remove it then you will have access to the back
  7. Samsung Watch Active Battery Replacement: passo 7, imagem 1 %32
    • Separate back fully from rest of the body
  8. Samsung Watch Active Battery Replacement: passo 8, imagem 1 %32
    • use tweezer to remove all 3 connectors and remove the screw
    The screw here is not the same as the ones on the back. This one is a phillips head (+).
    Rosalie E. Morgan - Responder
    of all the screw bits I have, I don't have this one,lol
    mnmacd - Responder
  9. Samsung Watch Active Battery Replacement: passo 9, imagem 1 %32
    • Use Spudger to lift panel housing from body
  10. Samsung Watch Active Battery Replacement: passo 10, imagem 1 %32
    • Remove housing from watch body
  11. Samsung Watch Active Battery Replacement: passo 11, imagem 1 %32
    • Lift off motherboard and use tweezer to lift up bettery connector from the plastic housing
  12. Samsung Watch Active Battery Replacement: passo 12, imagem 1 %32
    • use spudger to lift battey out of plastic housing
  13. Samsung Watch Active Battery Replacement: passo 13, imagem 1 %32
    • Separate battery from the plastic body, then install replacement battery
Conclusão
4 outras pessoas executaram este guia.
Jimi Aloba
Membro desde: 10/18/19
347 Reputação
Autoria de 1 guia
2Comentários do guia
I have so benefited from this portal , I have now made my own contribution. Hope it helps someone.
Jimi Aloba - Responder
Excellent guide Haven't done it yet. Where can I find the battery for this watch, also what type of screwdriver are you using for the 1st 4 screws? None of mine fit it.
mnmacd - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 38
Ao todo: 1,414
