Ir para o conteúdo principal
Samsung Stratosphere Front Camera Replacement
Ryan
Ryan e 3 outros colaboradores
Última atualização em May 7, 2024
35 - 45 minutos
Moderada
The front camera is on the same side as the phone's screen and is the only camera used to Skype on the Samsung Stratosphere.
O que você precisa
Ferramentas
Exibir mais…
  1. Samsung Stratosphere Front Camera Replacement, Battery: passo 1, imagem 1 %32
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
  2. Samsung Stratosphere Front Camera Replacement: passo 2, imagem 1 %32
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
  3. Samsung Stratosphere Front Camera Replacement, Motherboard: passo 3, imagem 1 %32
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
  4. Samsung Stratosphere Front Camera Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
  5. Samsung Stratosphere Front Camera Replacement: passo 5, imagem 1 %32
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
  6. Samsung Stratosphere Front Camera Replacement: passo 6, imagem 1 %32
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
  7. Samsung Stratosphere Front Camera Replacement: passo 7, imagem 1 %32 Samsung Stratosphere Front Camera Replacement: passo 7, imagem 2 %32
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
  8. Samsung Stratosphere Front Camera Replacement: passo 8, imagem 1 %32
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
  9. Samsung Stratosphere Front Camera Replacement, Front Camera: passo 9, imagem 1 %32
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
  10. Samsung Stratosphere Front Camera Replacement: passo 10, imagem 1 %32
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
  11. Samsung Stratosphere Front Camera Replacement: passo 11, imagem 1 %32
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
  12. Samsung Stratosphere Front Camera Replacement: passo 12, imagem 1 %32
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
  13. Samsung Stratosphere Front Camera Replacement: passo 13, imagem 1 %32
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
  14. Samsung Stratosphere Front Camera Replacement: passo 14, imagem 1 %32
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
  15. Samsung Stratosphere Front Camera Replacement: passo 15, imagem 1 %32 Samsung Stratosphere Front Camera Replacement: passo 15, imagem 2 %32
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
  16. Samsung Stratosphere Front Camera Replacement: passo 16, imagem 1 %32
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
  17. Samsung Stratosphere Front Camera Replacement: passo 17, imagem 1 %32 Samsung Stratosphere Front Camera Replacement: passo 17, imagem 2 %32
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
Conclusão
Ryan
Membro desde: 10/20/13
375 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-32, Amido Fall 2013 Membro de Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 505
