Samsung Stratosphere Display Replacement
Introdução
Vá para o passo 1This guide will show you how to detach and replace the phone's touchscreen display.
O que você precisa
Using your fingers, pry along the groove at the top of the phone.
Pull back on the rear casing until it comes free from the device.
The casing will make a cracking sound as it is removed.
Locate the red and white sim card located above the battery housing.
Remove the sim card by sliding it downwards from its slot with your fingers.
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
Pry the keyboard away from the casing with the plastic opening tool.
Carefully peel the blue tape from the bottom of the flex cable and set it aside.
Locate the clamp holding the gold display cable to the back of the screen.
Using the plastic opener tool, lightly pry the cable attachment into an upright position.
Once completed, the attachment should resemble the marked section.
13 outras pessoas executaram este guia.
Um comentário
Overall this was a great presentation. Very thorough and detailed, yet simple, with great pictures. Thank you.
