Ir para o conteúdo principal
Samsung Series 9 NP900X3A Back Panel Replacement
Zahir Sanchez
Zahir Sanchez e 3 outros colaboradores
Última atualização em May 24, 2018
1 - 5 minutos
Fácil
Melhor Introdução
O que você precisa
Ferramentas
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: passo 2, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: passo 3, imagem 1 %32 Samsung Series 9 NP900X3A Back Panel Replacement: passo 3, imagem 2 %32 Samsung Series 9 NP900X3A Back Panel Replacement: passo 3, imagem 3 %32
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 1,238
