Ir para o conteúdo principal
Samsung NX Mini Sensor Replacement
Kelsea Weber
Kelsea Weber e 4 outros colaboradores
Última atualização em 7 de mai de 2024
Nenhuma estimativa
Moderado
Introdução
Ir para o passo 1
This guide will show you how to access the sensor for cleaning or necessary repairs.
O que você precisa
Ferramentas
Exibir mais…
  1. Samsung NX Mini Sensor Replacement, Battery: passo 1, imagem 1 %32 Samsung NX Mini Sensor Replacement, Battery: passo 1, imagem 2 %32 Samsung NX Mini Sensor Replacement, Battery: passo 1, imagem 3 %32
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Sensor Replacement: passo 2, imagem 1 %32 Samsung NX Mini Sensor Replacement: passo 2, imagem 2 %32
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
    my battery is stuck, is there a manual release button or a way to remove the battery safely?
    beat70 - Responder
  3. Samsung NX Mini Sensor Replacement, Front Case: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Sensor Replacement: passo 4, imagem 1 %32
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
    You don't show us how to remove the top plate
    Bev Curran - Responder
  5. Samsung NX Mini Sensor Replacement: passo 5, imagem 1 %32
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Sensor Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Sensor Replacement: passo 7, imagem 1 %32
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Sensor Replacement: passo 8, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Sensor Replacement: passo 9, imagem 1 %32 Samsung NX Mini Sensor Replacement: passo 9, imagem 2 %32
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini Sensor Replacement, Sensor: passo 10, imagem 1 %32 Samsung NX Mini Sensor Replacement, Sensor: passo 10, imagem 2 %32 Samsung NX Mini Sensor Replacement, Sensor: passo 10, imagem 3 %32
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini Sensor Replacement: passo 11, imagem 1 %32 Samsung NX Mini Sensor Replacement: passo 11, imagem 2 %32
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini Sensor Replacement: passo 12, imagem 1 %32 Samsung NX Mini Sensor Replacement: passo 12, imagem 2 %32 Samsung NX Mini Sensor Replacement: passo 12, imagem 3 %32
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini Sensor Replacement: passo 13, imagem 1 %32 Samsung NX Mini Sensor Replacement: passo 13, imagem 2 %32
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini Sensor Replacement: passo 14, imagem 1 %32
    • Gently remove the sensor mount from the camera case.
Conclusão
To reassemble your camera, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Kelsea Weber
Membro desde: 11/12/15
20.810 Reputação
Autoria de 32 guias
1Comentário do guia
Hello,
I need to know the exact dimensions of the IR-cut filter in the Samsung NX Mini camera, which should be just above the sensor. Could you possibly give me that information? I need that because I’d like to modify my NX Mini camera and change it into an infrared camera. I have to cut an infrared filter in the right size, before the disassembly of the camera.
Thank you!
Siamak ADN - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 1,363
