Ir para o conteúdo principal
Samsung Gear S Speaker Replacement
Luis Franco
Luis Franco e 3 outros colaboradores
Última atualização em November 30, 2015
20 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
This guide will show step by step instructions on how to replace the Samsung Gear S speaker.
O que você precisa
Ferramentas
Exibir mais…
  1. Samsung Gear S Speaker Replacement, Display Assembly: passo 1, imagem 1 %32 Samsung Gear S Speaker Replacement, Display Assembly: passo 1, imagem 2 %32 Samsung Gear S Speaker Replacement, Display Assembly: passo 1, imagem 3 %32
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Speaker Replacement: passo 2, imagem 1 %32 Samsung Gear S Speaker Replacement: passo 2, imagem 2 %32
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
    is it a good idea to apply some heat first?
    ian stapleton - Responder
    Do we need to apply some heat?
    Ousmane Sokona -
    I found the use of a razor blade was very helpful. Very thin and I was able to lift the edge.
    oneothefewproud - Responder
    I would assume a small amount of heat would do wonders here...
    Gary Bartholin - Responder
    DO NOT USE A RAZOR BLADE! It instantly shattered my screen, right from the start!
    It is double sided tape, around the entire perimeter, and across the middle, upside down U fashion.
    You can see the glue remnants in Step 3’s photo. Heat it first, even with a blow dryer, as I did not.
    It *may* work with an Exacto blade, but not a regular razor blade, given my broken display.
    On top of that, the corner shown in the photo is not the corner you want a blade near, as it cut my wiring to the display!
    Use the top left corner, away from the cabling.
    The notes don’t tell you that you need to have an adhesive to reconnect the display, until the very end.
    But hey, they’ll sell you more parts if you don’t follow my advice.
    Brian Kinney - Responder
    You must have put the razor blade to far in because I used a single blade/ not the double side blade and it worked great and used the same adhesive by heating it up with a hair dryer.
    James fletcher - Responder
    Apply heat dont attempt to do this with out heat
    Christaphor Henrie - Responder
    ни в коем случае не отклеивайте экран, если только но не разбит! просто нанесите ушной палочкой изопропиловый спирт на обратную часть металлической рамки и просто отсоедините заднюю крышку. не трогайте экран!!!
    Alexandr Tarasov - Responder
  3. Samsung Gear S Speaker Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
    The metal rim has to bend away from the motherboard in order for this to come out. Use a guitar pick.
  4. Samsung Gear S Speaker Replacement: passo 4, imagem 1 %32
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Speaker Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Speaker Replacement: passo 6, imagem 1 %32
    • Now the watch should be in three separate pieces.
    Where does that piece to the left coming from?
    Ousmane Sokona - Responder
    After separating into three separate pieces what is the next move in order that this device will be functional again.
    Odnalor - Responder
    After the three pieces were already separated what will be the the next step or move in order to let this watch functional again.
    Odnalor - Responder
  7. Samsung Gear S Speaker Replacement, Speaker: passo 7, imagem 1 %32
    • Locate the speaker in the upper left corner of the housing.
    • Locate the speaker ribbon connector directly below the speaker.
  8. Samsung Gear S Speaker Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool to gently pry upwards on the speaker's ribbon connector.
  9. Samsung Gear S Speaker Replacement: passo 9, imagem 1 %32
    • Use the spudger to gently pry upwards on the speaker housing.
    • Note: The speaker housing is attached with adhesive, therefore, some force is required.
Conclusão
3 outras pessoas executaram este guia.
Luis Franco
Membro desde: 09/03/15
1.076 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-1, Blackwell Fall 2015 Membro de USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Membros
Autoria de 5 guias
2Comentários do guia
Do you have a place where we can buy the speaker part?
christopher borget - Responder
Ya. Looking for speaker part myself... Where we find it at?
Tony Tone - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Ao todo: 3,335
