Ir para o conteúdo principal
Samsung Gear S Display Assembly Replacement
Crystal Schmitt
Crystal Schmitt e 5 outros colaboradores
Última atualização em November 30, 2015
10 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
This guide shows how to remove the display of the watch from the rest of the watch.
O que você precisa
Ferramentas
Exibir mais…
  1. Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32 Samsung Gear S Display Assembly Replacement, Display Assembly: passo 1, imagem 3 %32
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Display Assembly Replacement: passo 2, imagem 1 %32 Samsung Gear S Display Assembly Replacement: passo 2, imagem 2 %32
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
    is it a good idea to apply some heat first?
    ian stapleton - Responder
    Do we need to apply some heat?
    Ousmane Sokona -
    I found the use of a razor blade was very helpful. Very thin and I was able to lift the edge.
    oneothefewproud - Responder
    I would assume a small amount of heat would do wonders here...
    Gary Bartholin - Responder
    DO NOT USE A RAZOR BLADE! It instantly shattered my screen, right from the start!
    It is double sided tape, around the entire perimeter, and across the middle, upside down U fashion.
    You can see the glue remnants in Step 3’s photo. Heat it first, even with a blow dryer, as I did not.
    It *may* work with an Exacto blade, but not a regular razor blade, given my broken display.
    On top of that, the corner shown in the photo is not the corner you want a blade near, as it cut my wiring to the display!
    Use the top left corner, away from the cabling.
    The notes don’t tell you that you need to have an adhesive to reconnect the display, until the very end.
    But hey, they’ll sell you more parts if you don’t follow my advice.
    Brian Kinney - Responder
    You must have put the razor blade to far in because I used a single blade/ not the double side blade and it worked great and used the same adhesive by heating it up with a hair dryer.
    James fletcher - Responder
    Apply heat dont attempt to do this with out heat
    Christaphor Henrie - Responder
    ни в коем случае не отклеивайте экран, если только но не разбит! просто нанесите ушной палочкой изопропиловый спирт на обратную часть металлической рамки и просто отсоедините заднюю крышку. не трогайте экран!!!
    Alexandr Tarasov - Responder
  3. Samsung Gear S Display Assembly Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
    The metal rim has to bend away from the motherboard in order for this to come out. Use a guitar pick.
  4. Samsung Gear S Display Assembly Replacement: passo 4, imagem 1 %32
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Display Assembly Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Display Assembly Replacement: passo 6, imagem 1 %32
    • Now the watch should be in three separate pieces.
    Where does that piece to the left coming from?
    Ousmane Sokona - Responder
    After separating into three separate pieces what is the next move in order that this device will be functional again.
    Odnalor - Responder
    After the three pieces were already separated what will be the the next step or move in order to let this watch functional again.
    Odnalor - Responder
Conclusão
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 12-1, Blackwell Fall 2015 Membro de USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Membros
Autoria de 5 guias
16Comentários do guia
Where can i get the LCD for Gear S
Kuek See Chuan - Responder
my screen flashing light and show on screen lines
avi mor - Responder
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - Responder
My watch is doing the same thing. Did you get a fix for it?
steve Walks -
There are flashing yellow lights on the screen, could I fix that?
Alex - Responder
how much is a kit.
wescott - Responder
Were can I buy the display ?
joseph - Responder
Where can i buy the lcd ?
Carlos Brandao - Responder
what kind of adhesive is best to reattach the screen to the watch?
tom - Responder
did anyone find out where to get the screen???
patrick jackson - Responder
How much buying lcd Samsung gear s
Mohd Azlan - Responder
When I turn my gear s on it says rebooting then screen goes black , that is all I can get watch to do, is there a fix for this?
Errol - Responder
Hi. I have this watch for 5 years now and I'm so happy with it. Unfortunately the wrist strap is almost broken. Where can I get new one?
tmicheva - Responder
I need an lcd screen where can I purchase two.
I have two gear solo watches that need replacements.
nvrlit77 - Responder
El mio lo usas funciona bien, derrepente la pantalla empieza a fallar como si alguien la estuviera presionando o usando y tiene vida propia hasta que decide funcionar, es una lastima porque es un reloj especial, cuando se le pasa la falla puede trabajar bien por tiempo prolongado, alguien sabe que puede ser?
Jesus Gordones - Responder
where can i get the ahesive to glue it back together?
sarahi medina - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 15,625
