Ir para o conteúdo principal
Samsung Galaxy S10 Screen Replacement
O que você precisa
  1. Samsung Galaxy S10 Screen Replacement, Heat the back cover: passo 1, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Heat the back cover: passo 1, imagem 2 %32 Samsung Galaxy S10 Screen Replacement, Heat the back cover: passo 1, imagem 3 %32
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy S10 Screen Replacement, Create an opening gap: passo 2, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Create an opening gap: passo 2, imagem 2 %32 Samsung Galaxy S10 Screen Replacement, Create an opening gap: passo 2, imagem 3 %32
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy S10 Screen Replacement, Insert an opening pick: passo 3, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Insert an opening pick: passo 3, imagem 2 %32 Samsung Galaxy S10 Screen Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Heat an iOpener and apply it to the same edge of the phone for two minutes.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances and strong adhesive, multiple attempts may be necessary to create a gap for the opening pick.
    • If you are having trouble creating a gap, the adhesive isn't weakened enough. Make sure you have heated the edge until just barely too hot to touch try this step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy S10 Screen Replacement, Slice through the adhesive: passo 4, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Slice through the adhesive: passo 4, imagem 2 %32 Samsung Galaxy S10 Screen Replacement, Slice through the adhesive: passo 4, imagem 3 %32
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy S10 Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 5, imagem 2 %32
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy S10 Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 6, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 6, imagem 3 %32
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy S10 Screen Replacement: passo 7, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 7, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 7, imagem 3 %32
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy S10 Screen Replacement, Remove the midframe: passo 8, imagem 1 %32
    • Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy S10 Screen Replacement: passo 9, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 9, imagem 2 %32
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the volume up button.
    • Pry up to loosen the midframe from the phone.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy S10 Screen Replacement: passo 10, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 10, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 10, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy S10 Screen Replacement, Disconnect the battery: passo 11, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Disconnect the battery: passo 11, imagem 2 %32 Samsung Galaxy S10 Screen Replacement, Disconnect the battery: passo 11, imagem 3 %32
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
    Pergunte ao FixBot
    Comentar
  12. Samsung Galaxy S10 Screen Replacement, Remove the loudspeaker: passo 12, imagem 1 %32
    • Remove the seven 4 mm Phillips screws securing the lower midframe.
    Pergunte ao FixBot
    Comentar
  13. Samsung Galaxy S10 Screen Replacement: passo 13, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 13, imagem 2 %32
    • Insert the point of a spudger underneath the top right corner of the lower midframe.
    • Pry up to release the midframe from the phone.
    Pergunte ao FixBot
    Comentar
  14. Samsung Galaxy S10 Screen Replacement: passo 14, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 14, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 14, imagem 3 %32
    • Grasp the loosened end of the midframe with your fingers and lift upwards slowly.
    • Wiggle the midframe slightly to help release the remaining edge clips.
    • Remove the lower midframe. The loudspeaker is built into the lower midframe.
    Pergunte ao FixBot
    Comentar
  15. Samsung Galaxy S10 Screen Replacement, Disconnect the screen: passo 15, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Disconnect the screen: passo 15, imagem 2 %32
    • Use the flat edge of a spudger to pry up and disconnect the display connector from its motherboard socket.
    Pergunte ao FixBot
    Comentar
  16. Samsung Galaxy S10 Screen Replacement, Slice through the screen adhesive: passo 16, imagem 1 %32
    • Flip the phone over so that the display is facing up.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the internal battery is susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  17. Samsung Galaxy S10 Screen Replacement: passo 17, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 17, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 17, imagem 3 %32
    • Apply a suction cup to the heated edge of the display.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    Pergunte ao FixBot
    Comentar
  18. Samsung Galaxy S10 Screen Replacement: passo 18, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 18, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 18, imagem 3 %32
    • Slide the opening pick along the right edge to slice through the adhesive.
    • Leave the opening pick in the corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
    Comentar
  19. Samsung Galaxy S10 Screen Replacement: passo 19, imagem 1 %32
    • Apply a heated iOpener to the bottom edge of the display for one minute.
    Pergunte ao FixBot
    Comentar
  20. Samsung Galaxy S10 Screen Replacement: passo 20, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 20, imagem 2 %32
    • Slide an opening pick along the bottom edge to slice through the adhesive.
    Pergunte ao FixBot
    Comentar
  21. Samsung Galaxy S10 Screen Replacement: passo 21, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 21, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 21, imagem 3 %32
    • Repeat the heating and slicing procedure for the remaining display sides.
    Pergunte ao FixBot
    Comentar
  22. Samsung Galaxy S10 Screen Replacement: passo 22, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 22, imagem 2 %32 Samsung Galaxy S10 Screen Replacement: passo 22, imagem 3 %32
    • Use an opening pick to pry open and slice through any remaining adhesive.
    Pergunte ao FixBot
    Comentar
  23. Samsung Galaxy S10 Screen Replacement, Remove the screen: passo 23, imagem 1 %32 Samsung Galaxy S10 Screen Replacement, Remove the screen: passo 23, imagem 2 %32
    • Thread the display panel connector through the frame.
    • If you're having trouble, you can choose to cut the display panel cable in order to remove the display.
    Pergunte ao FixBot
    Comentar
  24. Samsung Galaxy S10 Screen Replacement: passo 24, imagem 1 %32 Samsung Galaxy S10 Screen Replacement: passo 24, imagem 2 %32
    • Remove the screen.
    • If you are using a custom-cut adhesive, follow this guide for instructions on how to remove the old adhesive and attach the replacement screen.
    • If you're using Tesa tape to reattach the screen, follow this guide.
    Pergunte ao FixBot
    Comentar
Conclusão
After you've completed the repair, follow this guide to test your repair.
47 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
343.723 Reputação
Autoria de 915 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.236 guias
6Comentários do guia
Bonjour, est ce que le téléphone retrouve sa norme ip68 après le changement de l’écran ? merci d’avance
Bastian - Responder Compartilhar
Hello! The repair will not restore IP68 resistance. You normally need specialty presses in order to seal a phone to IP ratings.
Bonjour! Ça ne sera pas. Vous avez besoin de machines spéciales pour restaurer le téléphone sur IP68.
Arthur Shi - Responder Compartilhar
Can the rear lens cover be removed without having to remove the entire back? I have a foggy lens that needs cleaning.
Pasith Phommarath - Responder Compartilhar
Oui je veux un autre ecran
Bétina François - Responder Compartilhar
Je veux un autre ecran Samsung galaxy S10
Comentar
Visualizações:
Últimas 24 horas: 23
Últimos 7 dias: 152
Últimos 30 dias: 828
Ao todo: 166,363
