Ir para o conteúdo principal
Samsung Eternity Motherboard Replacement
O que você precisa
    • Remove the back battery cover.
    Pergunte ao FixBot
    Comentar
  1. Samsung Eternity Motherboard Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger, remove the phone's battery.
    Pergunte ao FixBot
    Comentar
  2. Samsung Eternity Motherboard Replacement: passo 3, imagem 1 %32
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Samsung Eternity Motherboard Replacement: passo 4, imagem 1 %32 Samsung Eternity Motherboard Replacement: passo 4, imagem 2 %32
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Eternity Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
    Pergunte ao FixBot
    Comentar
  5. Samsung Eternity Motherboard Replacement: passo 6, imagem 1 %32 Samsung Eternity Motherboard Replacement: passo 6, imagem 2 %32 Samsung Eternity Motherboard Replacement: passo 6, imagem 3 %32
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
    Pergunte ao FixBot
    Comentar
  6. Samsung Eternity Motherboard Replacement: passo 7, imagem 1 %32
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
    Pergunte ao FixBot
    Comentar
  7. Samsung Eternity Motherboard Replacement: passo 8, imagem 1 %32
    • Peel the button sensor on the side of the motherboard off of the case.
    Pergunte ao FixBot
    Comentar
  8. Samsung Eternity Motherboard Replacement: passo 9, imagem 1 %32 Samsung Eternity Motherboard Replacement: passo 9, imagem 2 %32 Samsung Eternity Motherboard Replacement: passo 9, imagem 3 %32
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
    Pergunte ao FixBot
    Comentar
  9. Samsung Eternity Motherboard Replacement: passo 10, imagem 1 %32
    • You have successfully removed the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Kevin Huang
Membro desde: 04/20/11
11 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-11, Regan Spring 2011 Membro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 2,586
