Samsung DP515A2G Hard Disk Drive Replacement
Introdução
Vá para o passo 1In this guide, I will show you how to replace the hard drive in a Samsung All-in-One Desktop DP515A2G.
O que você precisa
Put the Samsung dp515a2g face down on a surface that will not scratch the monitor.
Ferramenta utilizada neste passo:iFixit Opening Picks (Set of 6)$4.99
Gently insert an opening pick in the seam between the back panel and bezel.
Run the opening pick along the seam, carefully freeing the clips holding the back panel in place.
The back panel should come away without resistance.
Ferramenta utilizada neste passo:Phillips #000 Screwdriver$5.49
Remove the 3 screws highlighted in red with a 000 Screwdriver
Using the 000 Screwdriver remove the screw on each side.
The hard drive should pull free of the shroud.
4 outras pessoas executaram este guia.
