Ir para o conteúdo principal
Reverse Applique Patch
Brittany McCrigler
Brittany McCrigler e 5 outros colaboradores
Última atualização em January 28, 2025
15 - 20 minutos
Fácil
Introdução
Ir para o passo 1
Patch your jeans with a reverse applique. This technique is great for holes that have a large chunk of cloth missing. You can cut any shape and use any color fabric for the patch, so long as it is heavy-weight fabric.
  1. Reverse Applique Patch, Reverse Applique Patch: passo 1, imagem 1 %32 Reverse Applique Patch, Reverse Applique Patch: passo 1, imagem 2 %32 Reverse Applique Patch, Reverse Applique Patch: passo 1, imagem 3 %32
    • Examine the damage. Clip any long threads, and remove any debris from the hole.
    • Measure the damaged area.
    • In our case it looks to be 2" by 2".
  2. Reverse Applique Patch: passo 2, imagem 1 %32 Reverse Applique Patch: passo 2, imagem 2 %32
    • Draw any the shape you'd like your patch to be on a piece of paper. Be sure your design is at least 1/8" larger than the damaged area.
    • Cut out your design.
  3. Reverse Applique Patch: passo 3, imagem 1 %32 Reverse Applique Patch: passo 3, imagem 2 %32
    • Lay the cutout of your design over the hole in the jeans to make sure that it is the correct size and looks how you want it to.
  4. Reverse Applique Patch: passo 4, imagem 1 %32 Reverse Applique Patch: passo 4, imagem 2 %32 Reverse Applique Patch: passo 4, imagem 3 %32
    • Using a pencil, pen, or tailor's chalk, trace the design onto the jeans.
  5. Reverse Applique Patch: passo 5, imagem 1 %32 Reverse Applique Patch: passo 5, imagem 2 %32 Reverse Applique Patch: passo 5, imagem 3 %32
    • Cut the design out of your jeans.
    • Be sure to only cut one layer of denim, or you will cut through the back of your jeans and need two patches!
  6. Reverse Applique Patch: passo 6, imagem 1 %32 Reverse Applique Patch: passo 6, imagem 2 %32 Reverse Applique Patch: passo 6, imagem 3 %32
    • Take the scrap of fabric you will use for a patch and insert it into the hole.
  7. Reverse Applique Patch: passo 7, imagem 1 %32 Reverse Applique Patch: passo 7, imagem 2 %32
    • Slide the pant leg with the patch over the arm of the sewing machine.
    • You may need to remove the sewing machine table for the pant to fit over the sewing machine.
    • If you are still having trouble getting the pant around the arm of the sewing machine, you can rip the side seam of the pant leg to allow room to sew.
    • Be sure that the pant leg is around the arm, and that you are not accidentally sewing the two layers of the pant leg together.
  8. Reverse Applique Patch: passo 8, imagem 1 %32 Reverse Applique Patch: passo 8, imagem 2 %32
    • Adjust the sewing machine for a zig-zag stitch.
    • Set the stitch length to just under 1/2.
  9. Reverse Applique Patch: passo 9, imagem 1 %32 Reverse Applique Patch: passo 9, imagem 2 %32
    • Align the edge of the patch with the center of the pressor foot.
    • Be sure that the patch is laying flat.
    • Lower the pressor foot.
    • Begin sewing the zig-zag stitch, following the edge of the hole so that the zig-zag stitch covers the area where the two fabrics meet.
  10. Reverse Applique Patch: passo 10, imagem 1 %32 Reverse Applique Patch: passo 10, imagem 2 %32 Reverse Applique Patch: passo 10, imagem 3 %32
    • Sew all the way around the patch.
    • Overlap the stitching at the end with the first two or three stitches.
  11. Reverse Applique Patch: passo 11, imagem 1 %32 Reverse Applique Patch: passo 11, imagem 2 %32
    • Lift the pressor foot and needle.
    • Slide the pant leg off of the arm of the sewing machine.
    • Clip any threads, and admire your work.
Linha de Chegada
6 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.981 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 20.038 guias
2Comentários do guia
To keep the pattern from entirely fraying or catching on things, it may also help to flip the pants right-side-out and sew again around the pattern edge with the zigzag or a flat stitch.
Alisa - Responder
worked! i’ve been wearing these torn pants for years. thanks so much!
Meenal Raval - Responder
Comentar
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 147
Últimos 30 dias: 531
Ao todo: 19,858
