Introdução
This repair guide will solve the squeaks sound of the ceiling fan after few years of operation. Youtube guide available show how-to replace the two wear out ball bearing.
O que você precisa
Vídeo de Apresentação
First, remove the mounting screws of the plastic cover located along the brim, farthest from the centre.
The iron cage is firmly secured by three screws.
Out of the six mounting screws located along the inner circle, three of them will be the mounting screws for the iron cage.
Remaining six screws will be the mounting screws for the fan blade.
15 outras pessoas concluíram este guia.
4 comentários
my ceiling fan would sometimes not start and making rumbling sounds (bearings) i did not want to replace or tear down so lifted plastic cover on top and liberally sprayed machine oil over exposed bearing & through slots underneath wd 40 this has cured problem perfectly just dry bearings would probably be better to use spray grease if you have --cheaper than new fan or bearings and only a few minutes work
My fan was not working what probelm
Thanks! I took apart my fan, thank you to your precise instructions. Used lithium grease and right now, enjoying quiet fan in my bedroom
price of the ceiling fan bearing
