Ir para o conteúdo principal
Replacing Samsung Galaxy S4 SIM Card
Sam Goldheart
Sam Goldheart e 6 outros colaboradores
Última atualização em April 3, 2024
Nenhuma estimativa
Muito fácil
Introdução
Ir para o passo 1
Use this guide to remove or replace the SIM card in your Samsung Galaxy S4.
O que você precisa
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: passo 1, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: passo 2, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card: passo 2, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card: passo 2, imagem 3 %32
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Responder
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Responder
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, imagem 3 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, imagem 3 %32
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, imagem 1 %32 Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, imagem 2 %32 Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, imagem 3 %32
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Responder
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Responder
Conclusão
80 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
471.738 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.543 guias
3 comentários
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Responder
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Responder
Removing sim card tray?
G M Chadwick - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 62
Últimos 30 dias: 281
Ao todo: 248,876
