Ir para o conteúdo principal
Repairing a Dried-Out Sharpie Marker
Hannah Green
Hannah Green e um outro colaborador
Última atualização em September 16, 2023
10 - 15 minutos
Fácil
A Sharpie can quickly dry out if you leave the cap off too long or use it often, making it weaker or completely unusable. Many Sharpies are thrown away because of this.
If your Sharpie has become dried-out and hard to use, you can use this guide to revive its ink and keep it out of the trash.
For this guide, it is recommended that you wear gloves so that you do not get ink or rubbing alcohol on yourself.
  1. Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: passo 1, imagem 1 %32 Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: passo 1, imagem 2 %32
    • Remove the cap of the Sharpie.
  2. Repairing a Dried-Out Sharpie Marker: passo 2, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 2, imagem 2 %32 Repairing a Dried-Out Sharpie Marker: passo 2, imagem 3 %32
    • Use a pair of pliers to separate the black part from the grey part of the Sharpie.
    • This can be a little difficult, so you may need to use two pairs of pliers to pull them apart.
  3. Repairing a Dried-Out Sharpie Marker: passo 3, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 3, imagem 2 %32
    • Pull out the ink pad.
    • Only touch the sides of the ink pad so that you do not get ink on yourself.
  4. Repairing a Dried-Out Sharpie Marker: passo 4, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 4, imagem 2 %32
    • Draw the rubbing alcohol into the syringe.
  5. Repairing a Dried-Out Sharpie Marker: passo 5, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 5, imagem 2 %32 Repairing a Dried-Out Sharpie Marker: passo 5, imagem 3 %32
    • Drip the rubbing alcohol into the part of the ink pad that has a sponge with a hole in its center. Do this until the sponge seems saturated (or about 5 drops).
  6. Repairing a Dried-Out Sharpie Marker: passo 6, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 6, imagem 2 %32
    • Put the ink pad back in.
  7. Repairing a Dried-Out Sharpie Marker: passo 7, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 7, imagem 2 %32 Repairing a Dried-Out Sharpie Marker: passo 7, imagem 3 %32
    • Put the black part and grey part of the Sharpie back together.
  8. Repairing a Dried-Out Sharpie Marker: passo 8, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 8, imagem 2 %32
    • Put the cap of the Sharpie back on.
  9. Repairing a Dried-Out Sharpie Marker: passo 9, imagem 1 %32
    • Let the Sharpie set for 1-3 minutes.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 56
Duração total: 1,035
