Ir para o conteúdo principal
Repairing Tent Velcro
Brittany McCrigler
Brittany McCrigler e 3 outros colaboradores
Última atualização em March 16, 2016
5 - 10 minutos
Fácil
Patagônia
A loose piece of velcro can leave your tent prey to the wind. Sew it back on using a whip stitch.
While you can glue a piece of velcro back into place, some adhesives may cause the tent material to become brittle and tear. Sewing is a simple alternative.
In addition to velcro, this procedure works for sewing almost any other fabric component of the tent back into place.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Repairing Tent Velcro, How to Sew a Whip Stitch: passo 1, imagem 1 %32 Repairing Tent Velcro, How to Sew a Whip Stitch: passo 1, imagem 2 %32
    • Align the two pieces of material you will be stitching together.
    • Thread your needle and tie a knot in the end of the thread.
    • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
    • Drive the needle into the bottom layer of material from the back side.
  2. Repairing Tent Velcro: passo 2, imagem 1 %32 Repairing Tent Velcro: passo 2, imagem 2 %32 Repairing Tent Velcro: passo 2, imagem 3 %32
    • Pull the needle through the bottom layer of material.
    • Pull the thread taut.
  3. Repairing Tent Velcro: passo 3, imagem 1 %32 Repairing Tent Velcro: passo 3, imagem 2 %32 Repairing Tent Velcro: passo 3, imagem 3 %32
    • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
    • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
    • Pull the thread taut on the backside of the bottom material.
  4. Repairing Tent Velcro: passo 4, imagem 1 %32 Repairing Tent Velcro: passo 4, imagem 2 %32
    • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
    • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
  5. Repairing Tent Velcro: passo 5, imagem 1 %32 Repairing Tent Velcro: passo 5, imagem 2 %32
    • For the final stitch, come up from the back of the bottom material once again.
    • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
  6. Repairing Tent Velcro: passo 6, imagem 1 %32 Repairing Tent Velcro: passo 6, imagem 2 %32 Repairing Tent Velcro: passo 6, imagem 3 %32
    • Slowly start to pull the thread taut. As you pull, you will see a loop form.
    • Draw the needle through the loop.
    • Pull the thread taut, forming a knot.
    • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
  7. Repairing Tent Velcro: passo 7, imagem 1 %32
    • Ensure that the stitches are tight.
    • Cut any remaining thread, and admire your handiwork.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.748 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.474 guias
Um comentário
If you remembered to pack a needle, but forgot a spool of thread, and a field repair is in order: go see whether you packed any dental floss. If so, you have some hardy thread indeed, and if you bought the green minty kind, you may discover a whiff of mint now and again emanating from your repair site. I try to remember to buy the old string type of floss rather than the newer kind with flat bits, but if your needle has a big enough eye, you can thread either sort. Careful now, too thick a needle may give you threading holes larger than you want. If the repair is in a location that may leak, there are a wide variety of different things you can use to seal your sewn repair and enjoy a drier tent interior. As my preference is for canvas tents over nylon, I use beeswax, but I think a silicone spray would nicely seal a repair to nylon.
Brendan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 5,356
