Ir para o conteúdo principal
Repairing Canon Powershot Camera indicates low battery and shuts down
Philiipe
Philiipe e 2 outros colaboradores
Última atualização em February 19, 2016
Nenhuma estimativa
Moderado
Fotos de ação
Acidente de Marcação
Precisa de mais images
Guia colaborativo
Introdução
Ir para o passo 1
I get this «low battery», or not working camera few weeks ago. It seem this problem is quite frequent with the powershot cameras. We can see few answers here: Camera indicates low battery and shuts down. and also on this blog: http://lakeuk.blogspot.fr/2010/04/camara...http://lakeuk.blogspot.fr/2010/04/camara....
However this fixes does not seems to work for anybody, and are not really satisfactory. I looked deeper in my camera, and I found that the problem is a loose soldering connecting the battery pins to the main motherboard.
O que você precisa
Ferramentas
  1. Repairing Canon Powershot Camera indicates low battery and shuts down, Repairing Canon Powershot Camera indicates low battery and shuts down: passo 1, imagem 1 %32
    • First you need to remove the back cover of the camera, so that you can access the motherboard. Here is how it looks like with the backcover removed (4 scew removed for a powershot A1200). At the top, you can see the main pins connecting the battery contact to the motheboard, but it is difficult to access them.
  2. Repairing Canon Powershot Camera indicates low battery and shuts down: passo 2, imagem 1 %32 Repairing Canon Powershot Camera indicates low battery and shuts down: passo 2, imagem 2 %32
    • Then, i remove the screen (2 screws), so that the motherboard and the connecting pins are easylly accessible.
    • In the second picture, you can see that near the pins, there is a "+" and a "-" sign. Here, by gently pressing them with a screwdriver, I noticed that one of them was completly loose. That is the reason of the problem.
    • Then, it is simple to fix it by soldering the loose connection.
    • The problems comes from the fact that the battery pins are directly solded to the motherboard, therefore the force exerted to maintain the good contact with the battery is applied to the soldering, which may eventually brake.
    • Next, remount every thing in back order. Pay attention to keep the screen clean (remove any fingerprints), and every thing should work fine...
Conclusão
3 outras pessoas executaram este guia.
Philiipe
Membro desde: 11/01/13
207 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 69
Ao todo: 30,933
