Ir para o conteúdo principal
Regaining deleted files from empty trash in Mac OS X
Vishal Chaudhary
Vishal Chaudhary e 3 outros colaboradores
Última atualização em 19 de fev de 2016
Nenhuma estimativa
Moderado
Guia colaborativo
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
Introdução
Ir para o passo 1
Numerous times a user move an unwanted file to trash and delete using empty trash command. Doing this is as simple as that in Mac OS X. To move a file in trash simple right click the file and hit 'Move to trash' option. With the keyboard select the file and hit the 'Command-Delete' button. To Empty a Trash simply select 'Shift-Command-Delete' and to Empty Trash without confirmation dialog press Option-Shift-Command-Delete.
  1. Regaining deleted files from empty trash in Mac OS X, Regaining deleted files from empty trash in Mac OS X: passo 1, imagem 1 %32
    • Download a free demo version of Mac file recovery software. Install it on your Mac and launch the user interface to begin.
  2. Regaining deleted files from empty trash in Mac OS X: passo 2, imagem 1 %32
    • In the software interface, find the 'Deleted File Recovery' feature from the menu and click it to proceed.
  3. Regaining deleted files from empty trash in Mac OS X: passo 3, imagem 1 %32
    • After doing that, you need to select the hard drive or the volumes from the left side display. Here you can either choose the main hard drive or the selected volume. In the past if you have deleted many files then you can select the main hard drive. Once you select a volume or the hard drive upon which the action has to be taken, hit the 'Continue'
  4. Regaining deleted files from empty trash in Mac OS X: passo 4, imagem 1 %32
    • Now the scanning of the selected volume/hard drive begins. The software scans the entire hard drive scanning for the deleted files. It may take more or less of the time depending upon the size of the hard drive. After the scan is over, user can see a list of files that can be recovered in a tree structure.
  5. Regaining deleted files from empty trash in Mac OS X: passo 5, imagem 1 %32
Conclusão
3 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Vishal Chaudhary
Membro desde: 04/18/12
3.203 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 2,293
