RazorX DLX Electric Skateboard Power Button Replacement
Introdução
Vá para o passo 1This guide is intended to show you how to replace the power button on the RazorX DLX Electric Skateboard. The power button is a temporary switch that allows the battery to supply power to the motor. The power button is necessary to ensure safety and longevity of the battery itself. While troubleshooting be careful when handling wires and the circuit board. Before you start, make sure the device is powered off.
O que você precisa
Flip the skateboard upside down.
Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
Push the cover forward to slide it off.
Flip the skateboard back over.
Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
Separate the trucks and control module from the board.
Remove the 20 mm Phillips #0 screw.
Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
Disconnect the power button from the control module.
Pinch the two plastic tabs to remove the power button from the plastic body.
