Ir para o conteúdo principal
Razor A Handle Grips Replacement
Jordyn
Jordyn e 5 outros colaboradores
Última atualização em August 3, 2023
15 - 20 minutos
Moderado
Guia em destaque
Guia do aluno destaque
Introdução
Ir para o passo 1
Do your hands hurt or slip when riding your scooter? Chances are your handle grips need to be replaced. This guide will show you how.
  1. Razor A Handle Grips Replacement, Handle Grips: passo 1, imagem 1 %32 Razor A Handle Grips Replacement, Handle Grips: passo 1, imagem 2 %32
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: passo 2, imagem 1 %32 Razor A Handle Grips Replacement: passo 2, imagem 2 %32
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: passo 3, imagem 1 %32 Razor A Handle Grips Replacement: passo 3, imagem 2 %32
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jordyn
Membro desde: 10/09/12
565 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-13, Amido Fall 2012 Membro de Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membros
Autoria de 10 guias
1Comentário do guia
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 5,079
